    Seems to be some kind of keyboard lag, it works fine about 90% of the time (which is really bad), and almost every 10th keystroke i make is either ignored, lags, or duplicate/triple of what i was trying to type
    So i'll type the word "Free" and end up with Frrrre, or Fre alot
    This is damning, hopefully someone can help me fix this issue before I have to return the phone as defective! Thanks in advance
    11-24-2018 03:29 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? Are you talking about a keyboard app, or a hardware keyboard?
    11-24-2018 11:25 PM
  3. Damani311's Avatar
    Just using the default keyboard app that was stock on the phone
    Never had a problem with samsung keyboards before. It just doesn't read a keystroke, or it will put out eeee if i just hit e once, it feels like some kind of glitchy lag
    11-25-2018 12:04 AM
  4. B. Diddy's Avatar
    Which Samsung phone? Do you have a screen protector on? Does this persist in Safe Mode?
    11-25-2018 12:35 AM
  5. Damani311's Avatar
    Sorry I thougth this was a Galaxy S8 Active forum
    So a Galaxy S8 Active
    I don't think I needed a screen protector for Galaxy S8 Active so I don't use one
    Yes it still does it in safe mode.
    Also its not just the standard keyboard, when I use my slingplayer app that has a remote it does the same thing, sometimes missing presses or duplicating them
    11-25-2018 09:46 AM
  6. B. Diddy's Avatar
    Strange that it persists in Safe Mode -- that usually means it's a system issue or a hardware issue. Does wiping the cache do anything? https://support.t-mobile.com/docs/DOC-34311
    11-26-2018 12:19 AM
  7. Damani311's Avatar
    It does the same thing when I press the "volume on / vibrate / mute" toggle
    sometimes it works, sometimes it does nothing, sometimes it goes straight from "sound" to "mute" (2 clicks)
    is there maybe someway I can calibrate the screen? Or is it likely the the screen is just broken and this is not something I can fix?
    11-26-2018 02:24 PM
  8. B. Diddy's Avatar
    Sorry, but did you already try wiping the cache partition as I previously suggested?
    11-26-2018 03:45 PM
  1. How to can switch camera in full view of Pixel 3?
    By Yougeshwar Khatri in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 11-29-2018, 11:32 PM
  2. Problem with LG music player at LG G7
    By gae2012 in forum LG G7 ThinQ
    Last Post: 11-25-2018, 04:29 PM
  3. Problems with unlocked phone and AT&T?
    By InitialKev in forum Samsung Galaxy S9 & S9+
    Last Post: 11-25-2018, 08:24 AM
  4. Replies: 0
    Last Post: 11-24-2018, 01:10 PM
  5. Why is half of my text deleted when sent
    Last Post: 11-24-2018, 11:10 AM
