    Today and yesterday my phone has just died even at a reasonable battery level. It just went off at 14% yesterday and wouldn't come back on for an hour or so then came back on at 1% so I charged it back up to full and similarly the battery died as in the phone just went off at 35% and wouldn't boot back up without charging. Anyway I switched it off overnight and woke up with 75% when I switched it on and started using my phone this morning, however an hour or so later another power down and it won't boot back up also the charger isn't showing any activity or light but I have left it on charge regardless.
    Anyone have any ideas or suggestions please?
    11-25-2018 03:00 AM
  2. Kodak2's Avatar
    It sounds like you need to replace the battery. Depending on what phone you have it may need to be done at s phone repair shop.
    11-25-2018 05:33 AM
  3. methodman89's Avatar
    Another battery killing post. Stop running down your lithium ion batteries. The same will happen to your replacement. Google how to maintain a lithium battery.
    11-25-2018 11:15 AM
  1. Nofitications on lockscreen time out to fast
    By Mojave in forum Samsung Galaxy S9 & S9+
    Last Post: 08-23-2020, 08:23 PM
  2. How can I fix the S7 battery life?
    By deltaa350 in forum Samsung Galaxy S7
    Last Post: 11-27-2018, 12:41 PM
  3. Replies: 7
    Last Post: 11-26-2018, 04:45 PM
  4. Is a 2A out charger is harmful for a android phone battery?
    Last Post: 11-24-2018, 12:45 PM
  5. Samsung s9 Exynos battery life?
    Last Post: 11-24-2018, 06:07 AM
