    I have I.Am Buttons Earphones, which i previously used on my google pixel. If i adjusted the volume on my bluetooth headphones, (without having to fiddle with any settings) it would adjust on my phone. I.E. they shared the same volume control.
    Last week i bought the huawei made 20 pro. On this device, with the same earphones it seems the volume controls are separate. If my earphones are on max, there will be no sound if my phone is on minimum, and vice versa. Is there any way around this? to have a common control like on the pixel before ?
    11-25-2018 07:30 AM
  2. methodman89's Avatar
    Your description of your current controls sounds normal for non wired bt headset. Personally, I need to turn up the media volume to max, then I have full volume range on the headset.
    11-25-2018 09:47 AM
  1. HP Laptop won't connect to Blackberry STV100
    By mickR135 in forum BlackBerry Priv
    Last Post: 11-26-2018, 01:16 PM
  2. when trying to upload a photo on Foap taken on my mobile it says small size why?
    Last Post: 11-26-2018, 01:50 AM
  3. Can the Tab E Lite be connected to a tv via HDMI adaptor for screen mirroring?
    Last Post: 11-25-2018, 12:33 PM
  4. Why my phone vibration is not working
    Last Post: 11-25-2018, 09:48 AM
  5. Any Android app that tracks a touch to screen with timer?
    By amjmas in forum Google Play Store
    Last Post: 11-25-2018, 07:46 AM
