Is this on play store?
I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply.
https://forums.androidcentral.com/sh...d.php?t=409154
Printable View
Welcome to Android Central! What's "kolami we2012"?
I don't know.
21h later.
We obviously cannot help you if you don't respond.
2d later.
Presumably my suggestion was fruitful.
Why is it that my Infinix note4 phone can't play WE 2012 game. After I downloaded it's giving error notice
Welcome.
Downloaded from where?
This sounds like the Winning Eleven 2012 game we get asked about fairly often, for some strange reason. No one seems to know much about it, but I seem to recall this is/was a region locked game. Assuming 2012 is the year it was released, I highly doubt it'll be playable. Any time I have searched for info, I also find a lot of hits on "Pro Evolution Soccer," so it's possible the company changed the naming at some point.
Welcome to Android Central! I'm guessing you downloaded it as an apk from some random site. This never guarantees compatibility with your phone, and it's also a good way of getting malware, since most sites with apks do nothing to ensure security.
The app gets stuck at black background
what phone model
Where di you download the game from? It's not on Play Store
Welcome to Android Central. To reply to this thread and receive notifications when others leave comments please create an account. This link will help you do that... https://forums.androidcentral.com/as...-new-post.html
As me just saying eluded to, we will need more information.
To expand on Galactic Zoo's statement, if you didn't download it from the Google's Play Store there are any number of reasons the app isn't working for you. Just to name a couple, it could be a bogus app, it may not be compatible with your device.
I think I'm safe saying most around here would recommend only getting apps from Google, Amazon and your manufacturer's app store. Internet app stores are fair game for every sleazy sneezy app developer and you never know what you're going to get.
See this thread from December 2018, with further replies in November 2019 for some information - https://forums.androidcentral.com/as...not-start.html
We get this question a lot, for some reason. Not exactly sure why or where this app came from, but what info I could find suggests it's only available in one specific region. That alone could be problem. If you downloaded it from an official source like Google Play or direct from the developer, then I suggest you contact the developer directly.
Otherwise, consider the wider released Pro Evolution Soccer, which is what pops up on Google Play when doing a search for "Winning Eleven."
https://play.google.com/store/apps/d...p.konami.pesam
I have downloaded the game and when it comes to installation it is saying app is not installed. What's the issue here
Where are you downloading it from? Is the game named "WE12" or is this an abbreviation?
If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
WE12 is one of those hooky unofficial or modified apps. @op we cant help with this
Welcome to Android Central! Winning Eleven 2012 isn't on the Play Store. So if you got the apk from some random website, (a) there's no guarantee it'll be compatible with your phone (especially since it's an old underpowered budget phone), and (b) there's a relatively high risk of malware, since most random sites don't vet these apk files.
When I want to play the screen turns dark
It may also help if you tell us which Android phone.
https://forums.androidcentral.com/as...community.html
I try to play winning eleven 2020 on itel p15 with android version 9
Welcome to Android Central! Are you trying to install it from the Play Store or from somewhere else?
Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/as...community.html
When i open it it just shows black for over and it do not open
Welcome to Android Central! This is a recurring question, about Winning Eleven not working well on a device. If you do a search about Winning Eleven, you'll notice that we always ask the same questions:
1. Which phone?
2. Are you installing the game from the Play Store or from somewhere else?
Please register so that you can give that information, if you want someone to help: Join the Android Central Community! - Android Forums at AndroidCentral.com
