    When ever I plug in or remove power cord I get this message window with that shows battery info with an advertisement!
    The window is white with green font. Says the bterry percentage, how long until fully charged, etc depending on whether plug went in or out.
    The most annoying part (besides the advertisement) is that when I plug in or out it interrupts what I'm doing.... e.g. for Netfix I have have to close the window then restart the show. Charging isn't seamless anymore.
    There is an option to dismiss the ap in a three dot menu at top right of window, but it is never disabled.
    How do I get rid of this?!?
    12-05-2018 05:02 AM
  2. belodion's Avatar
    Does it persist in Safe Mode?
    12-05-2018 06:59 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! If it doesn't happen in Safe Mode, then you most likely installed an app that included this as a "feature." Uninstall apps one by one until the problem goes away.
    12-05-2018 10:36 AM
  1. My infinix note 4 just shut down when i plugged in charger
    Last Post: 12-05-2018, 10:36 AM
  2. Wireless Charging 5W with the Pixel 3
    By chad783 in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 12-05-2018, 06:23 AM
  3. Unread text messages not appearing
    Last Post: 12-05-2018, 01:25 AM
  4. Replies: 1
    Last Post: 12-05-2018, 01:24 AM
  5. Replies: 1
    Last Post: 12-05-2018, 01:22 AM
