    I used a fast charger and ever since the battery drains fast.
    12-09-2018 11:03 PM
  2. Haley Chris's Avatar
    Did you try doing a Factory Reset or Uninstall or disable any apps you don't use and your battery could be going Bad
    12-09-2018 11:33 PM
  3. Kodak2's Avatar
    If you want or need to replace the battery we would need to know what phone you have.
    To reply to this thread please sign up to Android central.
    12-10-2018 06:30 AM
  4. L0n3N1nja's Avatar
    Most any phone can have the battery replaced but due to the way most new phones are manufactured it's usually best to have a repair shop do it.
    You should take a look at your settings and see if you can determine what's draining the battery, try to fix the software before the hardware.
    12-10-2018 06:37 AM
  1. Bypass Photo & Gallery Apps when sending Camera phtos to SD Card
    Last Post: 12-11-2018, 06:23 AM
  2. I was out today and my sd card stopped working
    By SleepyFish in forum Android 7.0 Nougat
    Last Post: 12-10-2018, 03:53 PM
  3. Why does my note 9 zoom in my pictures when I send them through text?
    Last Post: 12-09-2018, 09:11 PM
  4. How do I force shut down my Android phone?
    Last Post: 12-09-2018, 09:07 PM
  5. Replies: 0
    Last Post: 12-09-2018, 06:49 PM
