    If I'm using the regular selfie mode to take a picture of my body, it looks totally normal until my face is in the picture. It suddenly decides that my body and face need to be wider. ?????? Why does it do this?? Can I stop it from doing that??
    12-16-2018 06:30 PM
  2. SpookDroid's Avatar
    Depends on the specific phone you have, but if you have something like a Samsung phone it usually has a 'Beauty Mode' filter that you can tweak. It's basically a 'face correction' mode so that the lens doesn't distort facial features, but sometimes the effect can go too far or the skin smoothing filter too hard.
    12-16-2018 07:49 PM
  1. Why is my HTC10 wanting me to login to my HTC account?
    Last Post: 12-17-2018, 08:41 PM
  2. Why is battery is drain and the on
    Last Post: 12-16-2018, 09:12 PM
  3. My phone can't shut down, touch light stays on tue power botton also not working
    Last Post: 12-16-2018, 05:30 PM
  4. Replies: 1
    Last Post: 12-16-2018, 05:28 PM
  5. Replies: 1
    Last Post: 12-16-2018, 04:25 PM
