    I is not working from 2. Years . Is there any need to change battery
    12-22-2018 07:05 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which device? Are you saying the battery hasn't been charging for 2 years? If so, you're right, there's a good chance the battery is dead. The ease of replacing the battery depends on if the battery is user-removable.
    12-22-2018 07:52 PM
  1. Unsure if I will use the smart-functions enough to justify buying this
    By Ninjasquirrel in forum Samsung Galaxy Watch
    Last Post: 08-13-2019, 10:44 AM
  2. Where on the Note 9 do I go to find notes I have created?
    Last Post: 12-22-2018, 07:55 PM
  3. Why is my apps stopped working
    Last Post: 12-22-2018, 07:53 PM
  4. Can Samsung Pay work without having to enter pin?
    Last Post: 12-22-2018, 07:12 PM
  5. How do I remove an sd card if my phone is off?
    Last Post: 12-22-2018, 06:51 PM
