1. abhishek143's Avatar
    Fingerprint option missing in honor 7a help
    12-23-2018 01:42 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are you able to set other screen lock options? Are you using the phone on a work account? If so, certain companies can require security protocols that prevent usage of biometrics, since they aren't the most secure method of locking a phone.
    12-23-2018 02:24 AM
  1. What means let in lamda expression for livedata observable?
    By Android Central Question in forum Software Development and Hacking
    Last Post: 12-24-2018, 12:58 PM
  2. Help with Android # keypad codes, please
    Last Post: 12-23-2018, 01:52 PM
  3. What does Triangle in moto x4 status bar indicate
    Last Post: 12-22-2018, 08:07 PM
  4. What means let in lamda expression for livedata observable?
    Last Post: 12-22-2018, 05:10 PM
  5. Can I use sim cards from 2 different countries in a Samsung J701-M?
    Last Post: 12-22-2018, 04:25 PM
