    is the usb problem or the device can not recognize it?
    12-24-2018 05:55 AM
  2. SpookDroid's Avatar
    Does the USB show as plugged in when you connect it? If so, is the USB Stick formatted properly (Android can only read FAT, FAT32, and ExFAT file formats)?
    If the drive needs power, chances are the phone won't be able to supply it and will need an externally-powered hub. Or if you haven't used the OTG connector with something else, it might be that it's damaged/not working.
    12-24-2018 12:39 PM
  1. why my s9 mobile frequntly hangs and it shall be restarted by force?
    Last Post: 12-24-2018, 06:35 AM
