    I dont have wifi need a way without using wifi
    12-27-2018 04:29 AM
  2. hallux's Avatar
    You'll need an IR emitter and an app to command it to emit the proper commands for your devices.
    If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
    12-27-2018 04:58 AM
  3. Rukbat's Avatar
    Google make android ir blaster. There are a few articles. (It's easy and pretty cheap.)
    12-27-2018 11:58 AM
  1. Replies: 2
    Last Post: 12-27-2018, 07:57 AM
  2. Why is my local wheathwr not shoeon
  3. Upgrade Galaxy Tab3 GT-P5210 to newer version
    Last Post: 12-27-2018, 05:02 AM
  4. How do I get out of the beta program
    Last Post: 12-27-2018, 04:59 AM
