1. Problematic Guy's Avatar
    Just turned my potato of a phone Lenovo A5000, and it just suddenly happened without warning. It's as if it was still charging, it's just faintly flashing on the middle of the screen. Tried rebooting multiple times, and I don't think the fiddling with the settings would do any good. I also tried to take a screenshot, but it appears that it doesn't show the glitch on the picture. I've also noticed that even while charging, it still flashes on the screen. I appreciate any help that'll come, thanks in advance.
    12-28-2018 10:07 PM
  2. belodion's Avatar
    Welcome.
    Back up your personal data while you still can.
    12-29-2018 06:16 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Are you able to boot normally to the homescreen, or do you only see the battery icon in the middle of the screen? When you see the battery icon in the middle of the screen, that usually means the device is completely powered off while you're charging it.
    12-29-2018 08:48 AM
  1. Why is my phone keep saying its overheating, when its not even hot?
    Last Post: 07-06-2020, 10:42 AM
  2. Can anyone help me about my lock screen wallpaper?
    Last Post: 12-31-2018, 08:45 AM
  3. The little plate in the charging port broke off. How do I fix that?
    By mikeisdaman66 in forum Samsung Galaxy S6 edge
    Last Post: 12-29-2018, 08:05 PM
  4. Why did my snaps disappear when i logged in a new phone?
    Last Post: 12-29-2018, 01:46 PM
  5. Help getting in phone
    Last Post: 12-29-2018, 09:06 AM
