    Every time I plug in the charger the phone displays supports normal reverse charging and data transmission, and only after switching off the charging sign is displayed. Sometimes however changing the charger to a Motorola turbo charger seems to work.
    01-04-2019 12:20 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does this happen when you plug into a wall outlet, or when you're using a portable battery/power bank?
    01-04-2019 01:14 PM
  3. Mukul Chugh's Avatar
    i am having the same problem but i haven't connected to as moto's charger but it does the same thing when connected to asus zenfone max(original max variant).plz help
    07-08-2019 11:07 PM
  4. vipankr's Avatar
    I'm facing same issue with my Asus Zenfone pro max m1 after last update.
    Phone not getting charged with Asus charger or data cable connected to laptop/PC.
    When I switch it off , only then it start charging with both Charger and datacable and continue to charge even on swithcing it ON, but it displays Reverse charging pop-up.
    If remove the charger and rec-connect, it again stops charging.
    07-30-2020 03:38 AM
  5. methodman89's Avatar
    Is the phone under 1 yr old?
    Here's the warranty info.
    Manufacturer Contact Info
    Website: https://www.asus.com/us/
    Support Phone: 812-282-2787
    07-30-2020 05:38 AM
  6. B. Diddy's Avatar
    Welcome to Android Central! Try wiping the cache partition: https://www.hardreset.info/devices/a...m1/wipe-cache/
    07-30-2020 10:38 AM
  1. Samsung 8 having trouble recognizing and responding to flash drive
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 01-04-2019, 04:05 PM
  2. How to use imperial measuments when logging food, Samsung Health
    By IronBob in forum General Help and How To
    Last Post: 01-04-2019, 01:35 PM
  3. How do I resize my photo to put in a locket
    Last Post: 01-04-2019, 01:28 PM
  4. why can i not login to my email on android devices but I can on my computer.
    Last Post: 01-04-2019, 01:17 PM
  5. Samsung 8 having trouble recognizing and responding to flash drive
    Last Post: 01-04-2019, 10:35 AM
