    Where is the setting that governs voivemail and stops ringing?
    01-07-2019 08:25 PM
  2. Android Central Question's Avatar
    01-07-2019 08:48 PM
  3. L0n3N1nja's Avatar
    I think you have do not disturb enabled.
    01-07-2019 08:49 PM
  4. VidJunky's Avatar
    I'm assuming you've called yourself to verify this, what does the caller hear? Do they hear any rings at all, does it ring normally for them except you hear nothing and then get a VM notification or do they just go to VM? Have you checked your Voicemail settings? Most services will allow you to set the number of rings before sending a caller to VM, so if it's been set to 1 or 0 you may not hear a ring before it is being redirected. Check your VM settings.
    Are you using a launcher or anything like that? Some times they can interfere with dialer and incoming calls.
    Are you using a service, like Google Voice, for VM or for a second number? I had issues with GV whenever someone would call my GV number and had to go in and tweak some of the settings.
    01-07-2019 09:20 PM
  5. belodion's Avatar
    Threads merged.
    01-08-2019 06:36 AM
  1. How can I stop getting prompts to update apps I don't even use??
    Last Post: 01-10-2019, 06:24 AM
  2. LG Stylo 3 - NO SOUND
    Last Post: 01-08-2019, 06:38 AM
  3. LG phone goes right to voicemail, will not ring or notify
    Last Post: 01-07-2019, 09:20 PM
  4. Replies: 2
    Last Post: 01-07-2019, 08:35 PM
  5. Replies: 0
    Last Post: 01-07-2019, 08:34 PM
