Help my huawei phone keep going off on its own what should I do
Well, so it started two weeks ago where it just hangs, goes off and comes on after hours. It normally comes on after 24 hours or less but now it's close to 48 hours and it hasn't come onðŸ˜
Help?
Re: Help my huawei phone keep going off on its own what should I do
Welcome to Android Central! Which Huawei phone? If you press and hold Power for about 20 seconds, does anything happen?
It's possible the battery or the motherboard failed. Hopefully you made sure your important data was backed up once it started acting up.
