Originally Posted by
Android Central Question Well, so it started two weeks ago where it just hangs, goes off and comes on after hours. It normally comes on after 24 hours or less but now it's close to 48 hours and it hasn't come on
but then when i try to connect it to power or press the power button, it shows a red and green light. Its a huawei phone by the way. Help?
Sounds like your battery is shot. If you can replace your battery, look into that. Otherwise, it might be time to look into getting a new phone.
