How can I access the recovery mode without volume+power keys-
Hello guys,
I have the following issue:
I just replaced my phone screen (HTC Desire 620G) and when I tried to turn it on again it showed me the HTC logo screen with powered by Android and then nothing, it keeps restarting to the same logo over and over again.
I have tried to do a hard reset by pressing the volume up/down + power, by pressing all of them at once, but nothing. It keeps restarting to the same logo.
Do you know what the problem would be and how can I solve it?
Thank you very much everyone. Your help is appreciate it.
Sergiu
Re: How can I access the recovery mode without volume+power keys-
Was everything working before you replaced the screen?
Originally Posted by
belodion Was everything working before you replaced the screen?
Yes, everything was working just fine.
It seems likely, or at least possible, that you caused unintentional hardware damage while doing the repair. What that might be, I don’t know, but others here may be able to suggest.
belodion It seems likely, or at least possible, that you caused unintentional hardware damage while doing the repair. What that might be, I don’t know, but others here may be able to suggest.
I have worked with care, as this is the 2nd time I replace the screen. So I don't know what would be the issue.
