    Hi, everyone.. My story begins like this:
    My previous battery on SG G850f was weak (original battery has 1860 mAh), but I could use it with no problem. I notice in July that when battery goes down to 3,4 %, signal (or network service.. I dont know how to tell that on English.. I mean straight lines that provide us ability to call someone ) dissapears suddenly and after few secunds my phone turned off. After few days, my phone suddenly shut down at maybe 10 % and became very hot. i opened it, and MY BATTERY BECAME BULGED as it want to explode...
    I bought a new BATTERY, and I have similar problem... It shut down on even 60% (sometimes, it turn off at 30%, 40%)... Also, battery charge period is very SHORT (one hour is needed for charging to 100% - that is IMPOSIBLE!!! HOW!!) Also, drainig of battery is very fast (it`s empty after less then a hour)... Please help me. What should I do? I forget to tell that I have problem with lamp on my phone.Shortly before my first battery die, I noticed that lamp sometimes doesnt want to light. It needs to restart.
    01-19-2019 07:57 AM
  2. methodman89's Avatar
    First, go to settings and battery and see what is using your battery so much. Post a screenshot. Then clear the cache partition and reboot. Check all your settings, paying attention to your unneeded bt, wifi and GPS being on unnecessarily. Good luck.
    neshkobitches likes this.
    01-19-2019 08:43 AM
  3. neshkobitches's Avatar
    Problem about strange battery behaviour-49371986_370322863787791_5687306104640372736_n.png
    This is a pic. Gps, bluetoth and other are turned off...
    01-19-2019 08:54 AM
  4. methodman89's Avatar
    Okay. Now you'll need to wait and see until the battery stats starts putting out the data
    01-19-2019 06:20 PM
  5. neshkobitches's Avatar
    Applications are not the problem. My previous battery could stay all day nearly with same apps.. Today, I noticed my phone began to shut down even at 90 and more %.. I am very nervous
    01-20-2019 12:50 PM
  1. My Nextbook + 8 a working problem so how do I fix it show me
    Last Post: 01-19-2019, 02:02 AM
  2. Samsung S7 shutting down at 45% even after fitting new battery?
    Last Post: 01-19-2019, 01:58 AM
  3. why is my battery draining so fast?
    Last Post: 01-18-2019, 11:08 PM
  4. horrible standby battery
    By DamianP in forum LG V40
    Last Post: 01-18-2019, 09:46 PM
  5. Download and storage problem
    Last Post: 01-18-2019, 02:51 PM
