    Charging rates
    01-20-2019 10:26 AM
  2. belodion's Avatar
    I’d mention the device if I were you. That does seem relevant.
    Tim1954 likes this.
    01-20-2019 11:08 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! You typically can't control the charging rate. If the phone has a quick charging feature, that requires a special quick charging cable/plug. If you're using that kind of quick charging, there might be an option to select normal charging in the system settings, but that's not universal.
    01-20-2019 03:53 PM
  1. How can i remove this smart cleaning app from LG Aristo2
    By Vicky Gomez in forum Ask a Question
    Last Post: 01-23-2019, 01:23 PM
  2. sir touch will not working how can i solv
    Last Post: 01-20-2019, 09:04 PM
  3. Why when i charge my tablet the battery decreases?
    Last Post: 01-20-2019, 03:58 PM
  4. How do i remove the settings icon( short cut) from the quick drop down menu
    Last Post: 01-20-2019, 03:56 PM
  5. Replies: 0
    Last Post: 01-20-2019, 09:38 AM
