A
Android Central Question
I'm having this problem in my LG V10. The battery draings very quickly. But above that, it behaves wierd, it gets turned off on its own sometimes, then when I turn it on agian the battery drops to 25 or 35 (Its always different). When I'm using the phone the battery drops down quickly, but when I leave it idle, it goes up again, for example while using it drops down from 70% to 45%, and when I don't use it for a while the battery goes up again to for example 60% or 55%. Is this just battery issue, or software issue. Will it be resolved just after factory resetting or replacing the battery, or is it some other problem? Kindly help guys.
