A Android Central Question Jan 25, 2019 #1 There is a 3rd party app which I have been using for a year and suddenly it stopped working . The issue is that the app is working fine when using Mobile data but its not working when using WiFi ..
B. Diddy Senior Ambassador Moderator Mar 9, 2012 169,741 11,158 113 Jan 25, 2019 #2 Welcome to Android Central! Have you tried different wi-fi networks, or only your home or work one? Upvote 0 Downvote
R ryanironson New member Jan 25, 2019 2 0 0 Jan 25, 2019 #3 No.. i haven't tried different wifi network i have tried my home network Upvote 0 Downvote
R ryanironson New member Jan 25, 2019 2 0 0 Jan 25, 2019 #4 Is there any thing I can do to make it work Upvote 0 Downvote
ManiacJoe Trusted Member Aug 5, 2015 6,328 8 38 Jan 25, 2019 #5 Is this the only app that does not work on your home wifi? Upvote 0 Downvote
B. Diddy Senior Ambassador Moderator Mar 9, 2012 169,741 11,158 113 Jan 26, 2019 #6 The reason to try it on a different wi-fi network is to see if the problem is related to your specific network, or something else. If the apps work fine on another network, then it's probably something with your router's settings. See this guide: http://forums.androidcentral.com/am...roubleshooting-wi-fi-connection-problems.html Upvote 0 Downvote
