    I just got one ui update on my note 9 and found there are two line like edge panel on both side
    Its function like back button on the nav bar but you need to swipe to operate it
    The problem is i want to get rid of that feature, anyone can help me?
    01-25-2019 08:28 PM
  2. chanchan05's Avatar
    One Handed Operation+ IMO better than the usual gesture operations. Just look for the icon in your app drawer and either set it up and use it or turn it off. I have mine setup and 100% invisible.
    01-25-2019 11:21 PM
  1. How do i see bluetooth transfer files on galaxy note 5
    Last Post: 01-25-2019, 11:14 PM
  2. Verizon S7 Edge cutting out when streaming music
    By Android Central Question in forum Samsung Galaxy S7 edge
    Last Post: 01-25-2019, 10:44 PM
  3. Replies: 1
    Last Post: 01-25-2019, 10:38 PM
  4. Security policy blocking my camera
    Last Post: 01-25-2019, 09:37 PM
  5. My favorites screen has changed. Do not like the change
    Last Post: 01-25-2019, 07:19 PM
