    I replaced the lcd on my moto e5 plus and screen will not turn on.it flashes a white light when connected to the charger.I tried holding the power button for 30 seconds (since that method worked for some of you )but still no response.Any advice would be appreciated thanks in advance
    01-27-2019 05:53 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! You did the replacement yourself? Have you done many of them before, or was this the first time? There could be a number of problems -- a loose or faulty connection, some damage while you were doing the replacement, a faulty replacement screen, for example.
    01-27-2019 06:28 PM
  1. Samsung Note 9 gap issue
    By Android Central Question in forum Samsung Galaxy Note 9
    Last Post: 01-28-2019, 09:21 AM
  2. Why should I stick to the s7 edge and not upgrade to the s9 or the s10?
    By MaxCaufield in forum Samsung Galaxy S9 & S9+
    Last Post: 01-27-2019, 07:07 PM
  3. Who to get gifs on keyboard
    Last Post: 01-27-2019, 06:32 PM
  4. Can anyone tell me how to remove glance
    By Android Central Question in forum Xiaomi Android Phones
    Last Post: 01-27-2019, 04:47 PM
