    I use a Huawei mate 10 lite and a pair of brand new JBL headphones. Sound will come out the left side, but only very quietly. I have tried several sound adjusting apps, and none of them make any difference. As stated, the problem doesn't occur in normal calls, only while playing music or talking on apps like discord. Any ideas?
    01-29-2019 03:58 AM
  2. methodman89's Avatar
    Do the headphones work okay in a different phone?
    01-29-2019 06:24 AM
  3. Rukbat's Avatar
    Or do different headphones work okay on your phone? (Both are the ways you troubleshoot a problem like that. If the headphones work okay in another phone - but other headphones work okay in your phone - it's not a bad phone, it's headphones that don't match the phone for some reason.)
    01-29-2019 11:49 AM
  1. Why Gyroscope is not working ?
    Last Post: 01-29-2019, 04:23 AM
  2. Replies: 1
    Last Post: 01-29-2019, 02:46 AM
  3. Replies: 1
    Last Post: 01-28-2019, 11:02 PM
  4. How can I get the floating icon black and white message off my phone
    Last Post: 01-28-2019, 10:59 PM
  5. Will installing Magisk overwrite my ROM or kernel?
    Last Post: 01-28-2019, 10:09 PM
