    I have a Huwawei Y635-L21 and the flashlight won't work when I scroll down the top notification tab thing. I went to the icon on the phone, it shows it's on but it's not, I turn it off and close it then open it again and it's still 'Open'. I tried opening the camera, but It can't open because 'a third party might be open (like a flashlight)', when in reality nothing is open. I don't know what to do, now I can't use my camera and my flashlight won't work.
    And when I charge my phone, sometimes it will show it's charging, but the percentage won't rise or would go down then eventually shut down. Then when it is efficiently charged and off the plug, it drains out pretty quick.
    01-29-2019 06:24 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! If you reboot the phone and then immediately open the Camera app, are you able to take a photo with flash?
    As for the battery, it sounds it's failing. From what I can tell online, it looks like the battery is user-removable, so try a new battery.
    01-29-2019 07:00 PM
  1. Why does my phone keep dropping calls whether I'm making a call or recieving one
    Last Post: 02-01-2022, 09:35 PM
  2. Use a tablet Sim on a Pixel?
    By bulls96 in forum Google Pixel & Pixel XL
    Last Post: 02-16-2019, 12:22 PM
  3. Why can't I change the storage location of photos taken on camera app?
    Last Post: 01-30-2019, 10:12 AM
  4. Y is my talkback settings blacked out
    Last Post: 01-29-2019, 07:02 PM
  5. Why can't I rotate the screen on my ZTE Blade V8?
    Last Post: 01-29-2019, 05:36 PM
