Going into recovery mode says "no command;" common fix doesn't work, read description
  • Start date Start date
A
Android Central Question
Model: Moto G6 Play
Android Version: 8
I'll describe all my steps:
I went into fastboot by holding down the power button and volume down at the same time on startup. I scrolled with the vol buttons few times to select recovery mode. Moto logo shows for a second, and then it shows the laying down android with "no command" above it. I looked it up and it said to hold down different combinations of buttons and it should work. I tried every combination with the 3 buttons I had. Any combo that included the power button just booted the device into normal mode and the ones that didn't did nothing.
What should I do? I'm having issues with my wifi connection and I heard clearing the cache partition can solve it, please help.
