    (I'm using a ****ty phone called Gionee P5 Mini)
    So i was charging my phone and it charges REALLY SLOWLY It was at 30% and I thought if I restarted my phone it would charge a little faster, So I restarted it and then it turned off and I waited for it to open up again but it didn't so I tried long pressing the the power on button and it still didn't open so I pulled the battery out and put it back in the phone again and opened it again and if you remember I restarted my phone when it was only 30% but when I opened the phone it was 91%! (Someone tell me if the battery or the phone is ****ed up or both)
    02-09-2019 07:12 PM
  2. Tim1954's Avatar
    I would start by taking the battery out and cleaning the contacts on the battery and device. After a time with the minuscule currents flowing across the contacts, a thin film can form that can hinder flow (of electrons).
    Also, check for movement or loosenes when the battery is in, it should be pushed firmly up against the contacts. In some earlier Samsung devices, I used to put a bit of packing under the bottom of the battery to push it up. A good way to tell if this is a problem is to give the device a firm bump and if it turns itself off, you have your culprit.
    02-09-2019 07:21 PM
  1. Mother-in-law android problem
    By Mythic Collector in forum Android 6.0 Marshmallow
    Last Post: 02-10-2019, 11:29 AM
  2. Task switcher problems
    By IamSavic in forum Samsung Galaxy S9 & S9+
    Last Post: 02-09-2019, 11:39 PM
  3. Message app Problems
    By John A82 in forum General Help and How To
    Last Post: 02-09-2019, 09:41 PM
  4. Android update help with S9 plus
    By SuperGravy707 in forum Android 8.0 Oreo
    Last Post: 02-09-2019, 09:13 PM
  5. Rca voyager Android tablet problems
    Last Post: 02-09-2019, 05:14 PM
