    When I try to download th app, I get the message the device is not compatible with this version.
    02-10-2019 11:32 AM
  2. hallux's Avatar
    Your OS is too old. You'll either need a new device or you'll need to find a 3rd-party ROM that uses a code base of a newer version of Android. IMO, the 3rd-party ROM is only a band-aid, eventually the minimum-supported version of Android for apps is going to be beyond what 3rd-party ROMs are supporting, you'd be better served getting a new (not just newer but current model) device for longest-term support for apps.
    If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
    02-10-2019 11:45 AM
  3. L0n3N1nja's Avatar
    I'd recommend a new phone, you're a good 3 years outdated on security updates.
    It also doesn't support all the frequencies and bands networks are currently using so service coverage isn't as good. On the chance you have Verizon, phone becomes a paper weight next year when they retire the CDMA network because it doesn't support VoLTE.
    hallux likes this.
    02-10-2019 12:16 PM
  4. Rukbat's Avatar
    If it's not an AT&T or Verizon variant Note 3, LineageOS may work for you. (There's a Pie equivalent.)
    02-10-2019 02:44 PM
  1. Android files suddenly don't appear on my PC
    Last Post: 02-15-2019, 03:22 PM
  2. Huawei Mate P20 Pro- Always on Display doesnt work with smart cover. Settings?
    By Android Central Question in forum Huawei Mate 20 & Huawei Mate 20 Pro
    Last Post: 02-12-2019, 12:28 PM
  3. How to add world time on lock screen?
    Last Post: 02-10-2019, 03:19 PM
  4. Replies: 1
    Last Post: 02-10-2019, 11:36 AM
  5. how to use android and ipod touch with bluetooth at the same time
    Last Post: 02-10-2019, 11:16 AM
