How do I learn the terminology of the settings in my applications
  • Start date Start date
A
Android Central Question
When I go into the settings of an application I get confused on what it means exactly. Such as , "this may change what you think you are seeing and other applications."
How do I find a tutorial of my settings in applications
Welcome to Android Central! Are you talking about the settings of a specific app, or the phone's main system settings menu? It's hard to guide you about specific app, since every app will have a different menu. If you're asking about the system settings, look at my guide (although it's admittedly a little out of date by now): http://forums.androidcentral.com/ge...ting-started-android-updated-2016-nougat.html
How do find a tutorial for explaining exactly what the settings are doing in an application
I don't understand what the settings mean such as in permissions when it says this may change what you think you see and other applications. I'm looking for a tutorial to explain how the apps function and what the settings do
Duplicate threads merged.
Can you give us an example of an app where you see that message, and tell us the exact message you see?
suba
