    I am unable to press front facing camera button. It says that its no more valid. My phone is Ulefone MIX. "Manual selection icons is no more valid".
    02-18-2019 07:23 AM
  2. belodion's Avatar
    Try it in Safe Mode. Tell us if no go. https://forums.androidcentral.com/sh...d.php?t=409154
    02-18-2019 07:43 AM
  3. Nojus's Avatar
    I tryed in safe mode nothing works for ne
    02-18-2019 08:17 AM
  4. belodion's Avatar
    Perhaps the front camera has failed?
    Nojus likes this.
    02-18-2019 12:51 PM
  5. Nojus's Avatar
    How to add screenshots ?
    02-18-2019 02:18 PM
  6. belodion's Avatar
    Thus:
    https://r.tapatalk.com/shareLink?sha...6&share_type=t
    02-18-2019 02:23 PM
  7. Nojus's Avatar
    This is what i get
    Attached Thumbnails Pls help me i cant switch to front camera from rear-screenshot_20190218-220257.jpg   Pls help me i cant switch to front camera from rear-screenshot_20190218-220318.png   Pls help me i cant switch to front camera from rear-screenshot_20190218-220324.png   Pls help me i cant switch to front camera from rear-screenshot_20190218-220343.jpg   Pls help me i cant switch to front camera from rear-screenshot_20190218-220534.png
    02-18-2019 02:23 PM
  8. belodion's Avatar
    So, although you have switched off Rotate To Front Camera, the manual control for that is not working?
    If so, try clearing the cache for the Camera app.
    Nojus likes this.
    02-18-2019 02:39 PM
  9. Nojus's Avatar
    I tryed. Still doesn't work.
    02-18-2019 02:41 PM
  10. B. Diddy's Avatar
    The message on the screen suggests that you turned on some Auto-Switching feature that automatically switches between rear and front cameras by "180 degree rotation" (although I'm not sure if they mean rotating from one landscape orientation to the other, or if they mean twisting your wrist, like Moto's twist gesture). Check the Camera app settings or the system settings for some gesture option that you can turn off.
    Or is that what you did already?
    02-18-2019 03:30 PM
  11. Nojus's Avatar
    I checked camera settings I cleared data, factory reset, downloaded different camera
    app and nothing.
    02-18-2019 04:32 PM
  12. belodion's Avatar
    That probably is indeed the hardware failure I suggested earlier, therefore.
    02-18-2019 04:52 PM
  13. Nojus's Avatar
    So how should I fix it ?
    02-18-2019 04:55 PM
  14. B. Diddy's Avatar
    For a hardware failure, the only fix is to replace the hardware. If the phone is still under warranty, contact the manufacturer. Otherwise, bring it to a repair shop.
    Nojus likes this.
    02-18-2019 06:37 PM
  15. belodion's Avatar
    Note that the cost of repair may be more than you are willing to pay, so get an estimate in advance.
    Note also that it is difficult to diagnose faults via a forum, so do not assume that I have necessarily diagnosed correctly.
    Nojus and Rukbat like this.
    02-18-2019 07:02 PM
  16. Nojus's Avatar
    Amm oke my camera just fixed and i dont know how. I just restared the phone and downloaded screen rotation app. And then i checked my camera and its all good right now wtf ?.
    belodion likes this.
    02-19-2019 05:04 AM
  17. Nojus's Avatar
    My camera automaticly swiches to front when i turn my phone upside down. The phone Ulefone MIX front camera is on the bottom of the phone not on the top. And when i turn the phone 180 degree (upside down) the view looks normaly like a regular
    camera.
    02-19-2019 05:22 AM
  18. belodion's Avatar
    I'm very glad that you fixed it.
    Nojus likes this.
    02-19-2019 06:12 AM
  19. dhmosz1's Avatar
    can you tell me the exact name from the app? because i have the same problem and i cant fix it
    07-25-2019 12:15 PM
  20. Nojus's Avatar
    amm It didint fix it I still have the problem It was just temporary.
    07-26-2019 10:46 AM
  1. Smart select and pin to screen
    Last Post: 03-15-2019, 12:28 AM
  2. Nice to be part of this forum
    By Patrick081 in forum New to the Forums? Introduce Yourself Here!
    Last Post: 02-19-2019, 06:25 PM
  3. How to lock apps in LineageOs
    By Eesa Ibrahim Khokhar in forum Legacy Android & Other OS's
    Last Post: 02-18-2019, 03:48 PM
  4. Update for note 9 bought from Singapore
    By Android Central Question in forum Samsung Galaxy Note 9
    Last Post: 02-18-2019, 12:31 PM
  5. Why i am not able to record my screen after new update of android
    Last Post: 02-18-2019, 05:28 AM
