    How do I turn on camera permission to use the led
    02-19-2019 04:22 AM
  2. Rukbat's Avatar
    Look for a lightning bolt. It probably has a line through it. Tap it and the line will go away. (That's "flash", which is what the LED is acting as.) Or, depending on the camera app, you might get a choice of on, off or automatic. (Forcing it on even if there's good lighting will eliminate some shadows - especially if the light source is behind someone and you're taking their picture. Photography 101.)
    Laura Knotek likes this.
    02-19-2019 03:45 PM
  1. how to put multiple time zone clocks on home screen in 'realme 2pro' mobile?
    Last Post: 02-19-2019, 04:28 PM
  2. ad seem every time ask mi how to resolve
    Last Post: 02-19-2019, 04:26 PM
  3. Replies: 4
    Last Post: 02-19-2019, 03:47 PM
  4. Why does my kyrocera C6745 shut off in the middle of turning on
    Last Post: 02-19-2019, 06:37 AM
  5. What is a negative symbol mean on the top of my screen on my contact
    Last Post: 02-19-2019, 03:56 AM
