Depends, what are you using to connect to your car? AUX? BT? This has actually nothing to do with Android because this is universal for all music playing devices sending audio to a speaker/headset. Whether it's an iPhone, a Zune, an iPod, Windows Phone, Android device, Windows laptop or whatever else you can think of. If you're connecting an AUX, then the phone decides the quality based on what hardware it has.
If AUX, the quality is decided by the phone HARDWARE, Mooncatt stated above. Mp3 file goes to the phone's built in DAC, which then converts it into analog format which the 3.5mm jack transmits.
Now the Mate 20 DOES NOT have a 3.5mm jack. I'd assume you're connecting it to a USB port on your car's system. If so, then it is the Car's own DAC in it's sound system that's being used, for better or worse. Same would apply if you're using the USB connection on your LG.
If you're using BT connection, then it would depend on the bitrate of the codec you're using to transmit. The LG G4 is pretty old. Not sure if it's capable of using AptX, but in all likelihood it's still using SBC codec to transmit, which maxes 320kbps. Newer phones like the Mate 20 are able to transmit the audio through BT using AptX HD (576kpbs) or LDAC(990kbps). Then you also have to consider your speaker system in your car. How new is the hardware? Is the receiver capable of receiving AptX HD (LDAC is so far Sony proprietary, so only Sony speakers/headsets have it).
If the car system is capable of receiving AptX HD, but the LG is only sending it in SBC quality, then that's what it will play. But if the Mate 20 sends it at AptX HD, then the speakers will play AptX HD.
03-20-2019 06:56 PM
