    I have a "Samsung Galaxy Tab 4 10.1" (16gb) that often, but not always, has a flickering screen followed by a very rapid battery drain then shutdown or, on occasion, a reboot. This does not happen while it is connected to a power source. I have read multiple forums on this, with differing solutions, so not sure what it is. As a side note, on storage, it shows the device storage at having only 1.6 gb of available space, and I have very few apps on it, so not sure if this adefects anything.
    03-23-2019 10:43 AM
  2. belodion's Avatar
    That may be a hardware or battery fault. Back up while you still can. We can advise how best to do that if you wish.
    03-23-2019 10:57 AM
  3. Rukbat's Avatar
    Sounds to me like the battery is developing a dendrite (Lithium Battery Dendrite links if you're interested). The only fix is a new battery. And, as belodion said, if you're not already backed up (you should always be - there's no backing up if you drop the phone and a car rides over it), Backing up an Android Device is one way.
    03-23-2019 02:35 PM
  4. jpen10's Avatar
    I've been posting this on several threads: There are masked videos running in the background of legitimate banner ads on "Cheetah" apps. My battery was losing 80% of its charge overnight. I read this article, uninstalled CCleaner (the only one I had on the list) and two other battery apps and my percentage was 91% this morning. https://www.xda-developers.com/cheet...-android-apps/
    03-24-2019 10:40 AM
  1. Can I mute the aperture lens on galaxy s 10?
    By Android Central Question in forum Samsung Galaxy S10 & S10+
    Last Post: 03-24-2019, 11:16 AM
  2. my fone is stuck on firmware updatei cannot get my fone off this screen
    Last Post: 03-23-2019, 05:06 PM
  3. Dual sim for unlocked version Samsung Galaxy S10e
    By Android Central Question in forum Samsung Galaxy S10e
    Last Post: 03-23-2019, 02:06 PM
  4. Samsung Galaxy Tab A unable to boot, take a charge, or enter recovery mode
    By monocledghost in forum General Help and How To
    Last Post: 03-23-2019, 01:31 PM
  5. Dual sim for unlocked version Samsung Galaxy S10e
    Last Post: 03-23-2019, 09:21 AM
