correct pin does not unlock s6+
Galaxy s6+ remains locked, even with correct pin. Firstly fingerprint scan didn't respond, so I tried pin. There is a pause then it takes me to (can't remember name of screen) my background pic, with alerts listed, ie, missed call, pic successfully downloaded, etc. If I select an alert, it takes me straight to the pin screen again. It does not say pin incorrect, just goes to that screen. Can't power off or restart, as it asks for pin...
Is there a hard power off? I tried holding the power button down to no avail
Re: correct pin does not unlock s6+
Welcome.
Try holding Power and Volume Down to simulate a battery pull.
Hi Belodian, tried it, even tried it for 15seconds, nothing happened. Even did 'power' and 'volume up', and just added another screenshot message to the screen!
Also, what is battery pull...to try and drain it?
Yes. On phones without removable batteries, a simulated pull can be done. Removing and reinserting the battery sometimes fixes stubborn problems.
Originally Posted by
nickpan Galaxy s6+ remains locked, even with correct pin. Firstly fingerprint scan didn't respond, so I tried pin. There is a pause then it takes me to (can't remember name of screen) my background pic, with alerts listed, ie, missed call, pic successfully downloaded, etc. If I select an alert, it takes me straight to the pin screen again. It does not say pin incorrect, just goes to that screen. Can't power off or restart, as it asks for pin...
If your sign into your Samsung account
Go to Findmymobile.samsung.com
And can unlock your phone remotely
Welcome to Android Central! You may have to press and hold Power and Vol Down together for longer -- maybe 20-30 seconds. And time it by looking at a clock or your watch, since 20-30 seconds is actually a pretty long time to hold the buttons down for.
Yes, hold until it happens. There's no reason to give up at 15s. I generally assume half a minute, but however long it takes.
