    It goes from 30 to 50 percent and then back down to 20, all while charging(on the original charger). We looked and found that the battery was swollen so we bought a new battery, the exact same one, and it didn't fix it. Is it the phone? The charger? The charging port? He's had it for a year and this just recently started happening.
    04-19-2019 07:22 PM
  2. Golfdriver97's Avatar
    Welcome to the forums. I'd try a different charging cable if you can. Use the plug but try a different cable. If it still happens, it's probably the port on the phone.
    04-19-2019 07:23 PM
  1. Where are my settings for bixby?
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 04-27-2019, 06:32 AM
  2. Contact names stopped showing up when they call note 9
    Last Post: 04-19-2019, 07:26 PM
  3. I just reinstalled rShopping List after a hard reset. How do I retrieve my data?
    Last Post: 04-19-2019, 06:42 PM
  4. Where are my settings for bixby?
    Last Post: 04-19-2019, 06:02 PM
  5. Replies: 0
    Last Post: 04-19-2019, 05:35 PM
