    Noticing battery life on Pixel 3XL was getting worse, set restrictions on background battery use on some apps. If ive done this for Kohl's app how is it still using battery? Ive not opened the app in days.
    04-19-2019 07:38 PM
  2. VidJunky's Avatar
    I'm not sure why an app that you haven't used in days is using a noticeable amount of battery period... I would try uninstalling it and install it again, see if the problem returns with the install and then go from there. It could be a bug with the last update to the app, probably not a phone issue if it only seems to be this app. While you're in the Play Store getting the app for reinstall you might look at the reviews and see what the people who are rating it 1 and 2 stars are saying.
    Laineyc likes this.
    04-19-2019 10:24 PM
  1. Why is my brother's battery percentage going up and down even while charging?
    Last Post: 04-19-2019, 07:23 PM
  2. Replies: 0
    Last Post: 04-19-2019, 05:35 PM
  3. Why cant i Use bitmoji in a comment on FB...it always goes to a separate post in Fb
    By Android Central Question in forum Samsung Galaxy S10 & S10+
    Last Post: 04-19-2019, 05:12 PM
  4. Replies: 0
  5. Is it possible to lock bootloader without using PC in redmi note 5 mobile
    Last Post: 04-19-2019, 10:21 AM
