    I have location tags turned on for my S9. But, some photos end up NOT storing location info.. some do. Not sure if there's rhyme or reason to why some pictures store location tags and some don't.
    04-24-2019 08:44 AM
  2. Rukbat's Avatar
    All taken with the same camera app? See if you have enough GPS signal to get a location where you aren't getting tags - use GPS Status & Toolbox.
    04-24-2019 01:21 PM
  3. ceebird's Avatar
    I have same issue. Same Galaxy S7 phone, latest Android OS, same camera app, at the same event in the same location (outdoors where GPS signal is plentiful) = some photos have GPS location and some do not ... seems random when it works and when it does not. Must be an Android software bug. HAS ANYONE ROOT-CAUSED THE ISSUE?
    09-29-2019 10:05 PM
  1. Why is my phone sending messages from 2 different numbers?
    Last Post: 04-24-2019, 01:22 PM
  2. Incoming calls are not showing contact names just numbers
    Last Post: 04-24-2019, 07:57 AM
  3. why i cannot save apps to SD card on my honor 8 lite?
    Last Post: 04-24-2019, 06:38 AM
  4. wats wrong with my huawei y530 wich is not turning on but sreen turning pink
    Last Post: 04-24-2019, 03:48 AM
  5. Why can I see the contact name on my phone when they call only the number!?
    Last Post: 04-24-2019, 12:01 AM
