    I have tried changing the Charging ports twice then it charge for a while and the same problem sets in again, Kindly help!
    04-27-2019 03:05 AM
  2. belodion's Avatar
    A bad battery?
    04-27-2019 05:00 AM
  3. methodman89's Avatar
    Wth is a techno WX3. Is this the subaru forum?
    04-27-2019 07:14 AM
  4. Mooncatt's Avatar
    You said you tried changing charging ports, but did you try a different USB cable? That's often the culprit for this symptom.
    04-27-2019 08:03 AM
  5. Kiprotich KE's Avatar
    Yea have tried other USBs but they doesn't fo any good. Doesn't charge either
    04-28-2019 02:33 AM
  6. Kiprotich KE's Avatar
    Tecno....
    04-28-2019 02:33 AM
  7. Kiprotich KE's Avatar
    I doubt if the battery is bad. When I charge with a similar model, it works well.
    04-28-2019 02:36 AM
  8. Rukbat's Avatar
    If the phone is using more power than it can draw from the charger, the battery charge will go down, whether it's being "charged" or not. (Current from the charger is going to whatever is using all that power.)
    04-28-2019 03:20 PM
  1. Why my mobile honor6x asking password
    Last Post: 04-28-2019, 09:44 AM
  2. Where is the clipboard ???
    Last Post: 04-27-2019, 12:31 PM
  3. I bought 2 days before huawei mate 20 but the mobile data is not working,
    Last Post: 04-27-2019, 09:18 AM
