    After updating my Samsung Galaxy A8 (2018) to Android 9.0 One UI, battery is being used up a lot faster. Does anyone else have the same problem as I do? Does anyone know any solutions to fix this?
    04-28-2019 04:20 PM
  2. methodman89's Avatar
    1st, do a cache partition wipe and reboot.
    After an OS update this big, it's usually a good idea, and the 1st thing to do if you have these new issues.
    04-28-2019 06:57 PM
  3. Alex B6's Avatar
    I had the same problem, wiped cache partition, did another reset and no luck. I rolled it back to android 8 and it's like a brand new phone, responsive and 1000 times better battery life. Phone is only 8 months old too.
    Roll it back to 8 and you will be happy.
    06-24-2019 08:03 AM
  1. Samsung trade in is horrible
    By gizzyman in forum Samsung Galaxy S10 & S10+
    Last Post: 04-29-2019, 05:24 AM
  2. Gionee a1 battery drains quickly after the display change
    Last Post: 04-28-2019, 05:21 PM
  3. is there any low level coding that can bypass screen lock in android phone?
    Last Post: 04-28-2019, 03:03 PM
  4. I have lost the sound on my Android tablet
    Last Post: 04-28-2019, 03:01 PM
  5. Is there another phone case that my Galaxy Samsung S6 active can fit into?
    By Android Central Question in forum Samsung Galaxy S6 active
    Last Post: 04-28-2019, 01:51 PM
