    I would like to use an interface that looks like Google's Pixel on my Huawei Mate Pro.
    Should I use a Pixel launcher or download stock android? Is the latter even possible? Which one is more effective (use less battery). Thank you.
    05-04-2019 06:14 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! I've never noticed any excessive battery drain with Nova. I highly recommend it.
    Laura Knotek likes this.
    05-05-2019 03:15 AM
  3. Laura Knotek's Avatar
    Same here. I've used Nova on all my Android devices, and it's worked great with no battery drain issues.
    B. Diddy likes this.
    05-05-2019 04:17 AM
  4. mgbosshogg's Avatar
    Nope. Not noticed any difference here.
    05-05-2019 04:38 AM
  1. Does the G7 Have a dark theme?
    By SteelSteve in forum LG G7 ThinQ
    Last Post: 05-17-2019, 08:51 PM
  2. Why does my media server keep turning off by itself?
    Last Post: 05-04-2019, 05:57 AM
  3. Does the Samsung Galaxy S10+ have a factory installed screen protector?
    Last Post: 05-04-2019, 05:49 AM
  4. What does gsvo and gsm mean on your call history
    Last Post: 05-03-2019, 10:59 PM
  5. S5 active and Zerolemon extended battery
    By datum9 in forum Samsung Galaxy S5 Active
    Last Post: 05-03-2019, 01:05 PM
