    It is on my screen
    05-09-2019 07:57 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which device do you have? Are you saying that some app needs Camera permission in order to use the camera flash LED light (e.g., a flashlight app)? If you see a window asking you to grant permission, then just tap the option to grant permission. Or you could go to Settings>Apps, select the app in question, then Permissions, and turn on Camera permission there.
    05-09-2019 10:33 PM
  3. Carol Jordan Edwards's Avatar
    How do I get rid of the message on my android phone saying "Turn on Camera permissions to use LED" ??
    07-06-2019 10:37 PM
  4. mustang7757's Avatar
    What phone you using?
    07-06-2019 10:42 PM
  5. B. Diddy's Avatar
    Welcome to Android Central! Also, which app are you trying to use? Is it an app callled "LED"? Go to Settings>Apps, select the app, then Permissions, then turn on Camera permission. I'm assuming the app in question is trying to use the camera LED flash, probably as a flashlight. The LED flash is technically part of the camera module, which is why apps need Camera permission in order to use the LED flash.
    EDIT: Just realized I had already replied to the original question in essentially the same way. @Carol Jordan Edwards, did you read through this very short thread before posting your duplicate question?
    07-06-2019 11:51 PM
  1. 2XL with Q Beta 3 on AT&T
    By strikeIII in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 05-14-2019, 07:06 AM
  2. Smart switch not connecting to phone since last update
    By VasN in forum Samsung Galaxy Note 8
    Last Post: 05-13-2019, 10:56 AM
  3. Replies: 5
    Last Post: 05-11-2019, 12:10 AM
  4. Replies: 2
    Last Post: 05-09-2019, 10:44 PM
  5. Why is my ringing not ringing
    Last Post: 05-09-2019, 10:37 PM
