    I am having OPPO a57 phone, can I change its charging to wireless one and how...
    05-12-2019 02:33 AM
  2. hallux's Avatar
    You would need a case that plugs into the charge port and adds wireless charging.
    05-12-2019 05:24 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Either a case (as mentioned by hallux) or a really ugly induction coil that you stick onto the back of the phone, with a cable that plugs into your USB port. Not worth it, in my opinion.
    05-12-2019 06:38 PM
  4. hallux's Avatar
    And either way, you need a functioning charging port so if your goal was to bypass a failed port you're SOL..
    B. Diddy likes this.
    05-12-2019 07:59 PM
  1. Is it okay to root on a Chinese ROM?
    By DomestikPolka in forum Xiaomi Android Phones
    Last Post: 05-12-2019, 01:43 PM
  2. My LG is stuck on Firmware Update!?
    Last Post: 05-11-2019, 10:43 PM
  3. what is Used com.samsung."networkui" in my activity mean
    Last Post: 05-11-2019, 10:40 PM
  4. Replies: 0
    Last Post: 05-11-2019, 12:52 PM
