Help What can i do to fix my samsung note 5 , it is not turning on.
I was using my phone and it ran down and died and then I put it to charge for a while and then I tried turning it on and it wont turn on. Instead a blue light comes in on the indicator
Re: Help What can i do to fix my samsung note 5 , it is not turning on.
Originally Posted by
Android Central Question I was using my phone and it ran down and died and then I put it to charge for a while and then I tried turning it on and it wont turn on. Instead a blue light comes in on the indicator
Can you go into recovery?
Is the blue light "pulsating" or steady? If it's pulsating, the phone is accessing storage. (I suspect that what happened is that your "while" wasn't long enough. Turn it off, put it on the charger for about 3 hours, then see what happens.
If after 15 minutes of a pulsing blue light (or if the light isn't pulsing), see if you can get to the download screen (Home+Volume Down+Power). If you can, you can always flash the ROM again. (See [Samsung] How to flash Stock ROM via ODIN.)
If a few hours on the charger doesn't fix it, or it turns on, then shuts off after a few minutes, it needs a new battery. It's 5 years old - after 2 years the battery doesn't owe you anything. (They're only $10-$15, or $34 for the Taeozi extended battery [8800mAh].)
Sounds like the charger port is bad or the cable. Are you using a wireless charger? What have you done so far, still have it?
