    Is there any way to remove the chin from an LG G5 without breaking anything? My release button doesn't do anything. Pressing it, forcing it out, doesn't do anything.
    Notes: this is a 2nd hand phone, and on the chin connection, there is some sort of dried out super glue. I'm not sure if it is super glue or not.
    05-20-2019 10:50 PM
  2. Mike Dee's Avatar
    Did it ever work properly or is that how you received it?
    05-20-2019 11:27 PM
  3. ivanraptor730's Avatar
    It is how i recieved it.
    05-21-2019 12:02 AM
  4. Mike Dee's Avatar
    Well then I guess the button probably failed so the prior owner glued it based on what you have described. If this was purchased on eBay or Swappa you should try to return it. You might be able to get it apart without damaging it but that's a risk you would assume. I'm going to assume you're trying to change the battery?
    05-21-2019 05:27 AM
  1. Let's see the battery life
    By RaRa85 in forum OnePlus 7 & OnePlus 7 Pro
    Last Post: 01-15-2020, 05:13 PM
  2. Help with watchmaker battery charging status code at Android 5.1
    By Android Central Question in forum Android Wear / Wear OS
    Last Post: 05-24-2019, 07:12 PM
  3. Battery phone case, or cases that can handle wireless charging?
    By JnEricsonx in forum General News & Discussion
    Last Post: 05-20-2019, 07:57 PM
  4. LG Model Sizes
    Last Post: 05-19-2019, 11:59 AM
  5. LG G5 (F700L/KR) - Port to english ROM?
    By Android Central Question in forum LG G5
    Last Post: 05-19-2019, 11:55 AM
