    Hello, I have the Elephone A5, Android 8.1, but apear a problem, the battery stuck on 100%, and his not reading the sistem and APP consum. But its charging and discharging normaly, whith the battery percentage allways at 100%. How can I solve This problem? And can you tell me wen you Will update de sistem to 9.0? Thanks for your atention!
    05-24-2019 06:55 PM
  2. belodion's Avatar
    Try first a Power Off and Restart. If no go, try Safe Mode. If still no go, well...I don't know; a bad battery or battery chip perhaps.
    Android Central has no affiliation with Google. Your device manufacturer may have something to say about updates on their support website.
    05-24-2019 07:22 PM
  3. rob w5's Avatar
    My a5 does the same , can't seem to find anything to help
    03-18-2020 05:39 AM
  4. B. Diddy's Avatar
    Welcome to Android Central! You're talking about a Galaxy A5? And you've already tried Safe Mode as well? How about a cache partition wipe? https://www.hardreset.info/devices/s...17/wipe-cache/
    03-18-2020 12:57 PM
  5. mustang7757's Avatar
    I would use the phone until it turns of by itself and charge it to 100 % see if this recalibration corrects the battery
    03-18-2020 01:40 PM
  1. Thoughts on Tmobile changes especially Netflix
    By Ms Charli in forum General Carrier Discussion
    Last Post: 06-08-2019, 03:53 PM
  2. Two newbie questions - battery drain and autolaunch
    By 955450 in forum Android Auto
    Last Post: 05-25-2019, 02:44 PM
  3. How can I recover a file that autosaved over a version on my tablet?
    Last Post: 05-24-2019, 11:53 PM
  4. Phone won't turn on
    By TechNut79 in forum Verizon HTC One
    Last Post: 05-24-2019, 02:57 PM
  5. What is the difference is between Auto vs Always On when looking at the WiFi
    Last Post: 05-24-2019, 01:00 PM
