my battery problem
Rty809er
6
My screen use my battery life %50 i do not use my phone %100 5 hours later %50 and my phone screen use my battery why my phone has sleeping mode but use screen why phone null not use my screen use my battery life
my phone specification
It has 5.5 inches FHD (1080×1920) IPS display.Powered by 64-bit Octa-Core 1.3 GHz CPU built-in MediaTek MT6753 Soc.2GB RAM and 16GB internal storage, Expandable up to 64GB via microSD card.13 Megapixels rear camera and 5 megapixels front camera.Runs on Android 5.1 lollipop OS.Fingerprint scanner.It measures 155.3×77.2×8.6 mm and 165 grams weight.Connectivity options 2G, 3G, 4G LTE, Wi-Fi 802.11 b/g/n, Bluetooth v4.0, GPS, A-GPS, 3.5 mm audio jack.Powered by 3,000 mAh battery.
Welcome to Android Central! Keep in mind that this is a community forum, not an official tech support site, so you won't necessarily get support immediately.:)
Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
Thank you so much
markhenry493
