    I'm trying to use Miracast (or a similar app), to sync my screen on a monitor, while keeping the sound on my Android device.
    Because I would like to use headphones, and the monitor doesn't have a headphone output. So I would like to keep the sound on my Android device.
    I'm using:
    -Samsung Galaxy S7
    -a cheap 25$ AnyCast stick
    -HDMI Monitor (without headphone input/output)
    By the way, I don't have internet or a router, that's why I use Miracast.
    Thanks for any ideas!!
    05-28-2019 01:15 PM
  2. SpookDroid's Avatar
    Unfortunately there isn't a way. When screen mirroring, the audio will always be routed on Casting/MiraCast/Smart View. The only option that would give you that choice is via HDMI (can't remember if the S7 line is the one that didn't include HDMI support, though).
    However, even if you could on wireless mirroring, that would not be a pleasant experience. The video would lag behind the audio at all times.
    05-28-2019 04:44 PM
  3. Rukbat's Avatar
    The only option is a long 3.5mm extension cord and plug the headphones into the TV.
    05-28-2019 05:06 PM
  1. Wallpaper distortion on my phone
    By Android Central Question in forum More Huawei Phones
    Last Post: 06-01-2019, 04:40 PM
  2. How do I make the 3 in 1 HDTV Cable have sound on the TV?
    Last Post: 05-29-2019, 01:49 PM
  3. Will an unlocked red hydrogen one work on sprint?
    By Android Central Question in forum General Help and How To
    Last Post: 05-28-2019, 06:45 PM
  4. A New Symbol has popped up on my Phone
    Last Post: 05-28-2019, 10:55 AM
  5. Ad pop--up on my tex message
    Last Post: 05-28-2019, 08:57 AM
