    I have an 8 gig Samsung J5. I get a message - Running our of memory space, only 400mb left. What can I do to delete stuff like Microsoft apps?
    05-29-2019 11:15 PM
  2. belodion's Avatar
    Settings, Apps, select apps to be deleted, then Clear Cache, Clear Data, Force Stop, Uninstall. Only apps you've installed yourself can be deleted in that way.
    From time to time, clear your Cached Data in Settings, Storage.
    As you have discovered, using low-storage devices can be frustratingly difficult.
    05-30-2019 06:03 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! If the Microsoft apps were preinstalled, chances are you can't remove them unless you root the phone. You can probably Disable them in Settings>Apps, which can reduce their size since it forces them to revert to the smaller factory-installed version (updates are typically larger).
    06-01-2019 10:55 PM
  1. Can't receive pictures on messages
    By 1814 in forum Ask a Question
    Last Post: 06-01-2019, 10:50 PM
  2. Messenger says I have a page message, click on it nothing happens!
    Last Post: 05-30-2019, 11:42 AM
  3. Samsung flex refrigerator tablet
    Last Post: 05-30-2019, 08:33 AM
  4. Samsung Note 9 Notification's Won't Stay on Mute
    Last Post: 05-29-2019, 07:01 PM
