    basically my galaxy s6 (not edge) was dropped in about 3cm of melon juice but not flat down, vertically upside down so only the top 3cm of the phone were wet. when this happened either after or before my phone ran out of charge and buzzed like normal. now my screen wont work as it stays off, ive tried restarting and the LED notifications work, like when its chargeing or when i restart the phone it flashes blue and even the white symbols either side of the home button come on but the screen stays black and unresponsive.
    06-03-2019 01:22 AM
  2. VidJunky's Avatar
    It sounds like the phone is turning on but the screen is too damaged to work. Have you tried turning it on and calling it to see if it still rings? If you're lucky it's just the screen and most can be replaced.
    06-03-2019 01:57 AM
  1. Why is the talk to text on my new Galaxy S10 so awful?
    Last Post: 06-20-2019, 03:22 PM
  2. Why do some of my contacts have a blue dot by them
    Last Post: 06-02-2019, 11:39 PM
  3. Nib in my Samsung S pen is broken INSIDE!!
    Last Post: 06-02-2019, 09:56 PM
  4. Why Is fb messenger making my screen go crazy.
    By James Patterson7 in forum Android Apps
    Last Post: 06-02-2019, 09:44 PM
  5. Why Is fb messenger making my screen go crazy.
    Last Post: 06-02-2019, 09:30 PM
