    unfortunately accessibility has stopped how fix this problem. Ihave updated last update not fixed. I have resetted factory reset not fixed
    06-11-2019 10:05 PM
  2. VidJunky's Avatar
    What Accessibility feature is not working?
    Can you access Accessibility at all?
    Are you using any apps that aid or have Accessibility functions?
    When you factory reset are you choosing the restore option for apps? If an app is the cause starting your device in Safe Mode should reveal if it is a device problem or a bad app. If it is a bad app everything will work as it should until that app is opened. This should show you how to do this;
    https://www.google.com/url?sa=t&rct=...WT2u-LuOL6lyCC
    Become a member to reply in this thread. Having a two way conversation makes getting help easier.
    Laura Knotek likes this.
    06-12-2019 12:00 AM
  1. Why does Blocked Number Storage use memory on my tablet?
    By jdcrutch in forum Ask a Question
    Last Post: 09-19-2019, 10:07 PM
  2. how do i get the google weather icon on notification bar android
    Last Post: 06-12-2019, 08:11 PM
  3. How do I change the talk to text microphone?
    Last Post: 06-11-2019, 09:55 PM
  4. Replies: 1
    Last Post: 06-11-2019, 09:20 PM
  5. How do I bring ip my junk folder on my phone
    Last Post: 06-11-2019, 08:14 PM
